got to do a monolith at last
should have taken better pictures though:sneaky2:
fracture pruned the lower limbs and coronet cuts on the top also bored holes but you cant see them in the pics
Is that Rickerby Park ?
Is that the Beech that got a lightning strike or one of the many destroyed by the sheep ?
Is that B-Rob you are working for ?
yeah they dont take long on little machines, undo the greaser pull the idler back in with a strap pop the track on and your away. i had a track let go on a 25 tonner climbing up the side of the chip pile to load an artic with wood fuel......... that took more that an hour to put back on!!
the grease nipples were 11mm, pita as i didnt have a ratchet or spanner, so out came the shifter, but as you say if you are on the level and its dry its almost enjoyable, i cant imagine how you would wrestle a track off a 25 tonner
dragged it down the pile with another 25 tonner and refitted on the ground, used a hand winch and the other digger to align the track due to the weight of it...... at least it wasnt muddy...downright miserable then
