I think it's designed for dynamic rope but I've used a cinch for cple of years now on my lanyard with ap and it works absolutely fine. I try and get my lanyard taught so it won't shock load if I dropped into it, but tbh it's slack most of the time. I also use it as my ground belay for srt, as it's never in a shock load situation I don't see it being a problem. Also use it for rads when doing building access and again it's fine. But, it is designed fir dynamic rope.
  • Replies 23
what if your srt line anchor snaps out drew? and then the cinch is shockloading on a static line? which could happen as you very much well know.
maybe a drop test on this would be gd? but i could imgaine it would be fine, it mite lock too hard and give you a massive shock. as to lets say a vt system or gri gri etc.
Bro, my anchor point snapped and it put no shockload on th base, it was all freefall:) it was a bad choice of anchor not a bad choice of base belay. Give me a cinch to destroy and we'll test it bro. If it is a dodgy anchor and you have no choice, I just chuck in a shock absorber. Is any device designed for anchoring a static line? Does the isc descender(ab) work well here?
