1.Dont fall out the tree
2.Bribe the nptc bloke
3.Dont drop the saw out of the tree
Erm not much els
Oh best of luck m8 hope you pass
Go steady and make sure your cuts are accurate. Make sure you take time getting into the best working position and the rest will be easy.
Dont rush!! Good luck
As said above.... Just get yourself into a really good work position. As long as you do your cuts will be no harder than doing a CS30 and loads easier than a CS31!
confirming the above - the better the work position the easier the cuts! >90% of times spent getting into WP and moving around compared to the minimal time the saws working.
and the more chainbrake the more safer your work ethic looks!
I had a near 0 degree vertical main rope (on a cambium saver), strop/lanyard on right side D and a tiestrap as a left foothold and was cutting nowhere near any of `em.
utilise the slack main rope too if it aids getting into a good work position?
I`m a rookie sure but its still fresh in my mind ;)
