  • Replies 20
We supplied 2 hyd Jensens to a Large Contractor in Scotland for the front of their RR mogs, initially they were only partially successful but I believe they are now working well.
Steve, you know the company they bought your front mount schliesing from you???
can you post some pics off the input shaft into the chipper. what are you going to run it off ? ps remember if you are going to run it hydraulic you will need a crossover valve that will cope with the momentum off the flywheel it will need to be plumbeb in series between the valve block and the motor or it will break driveshafts etc
or put an over-run clutch on it between the motor and the flywheel.
