Does anyone know how veneer wood is cut? Is it possible to buy a machine that'll do it from home, or is there places you can take your own wood to to have them do it?
Yes I do need it thin, about a mm, it has more flex in it then and it's for making my rings. I tried cutting some on my bandsaw but it seems to be really brittle so you can't bend it at all. I wonder if there will be anyone at the APF doing it?
to get thin pieces of wood on small bits of work i find that using a potato peeler on green wood works for me and then wash under cold water to get the sappy crap off. You will have a bit of playing time with the wood as its flexi because green, sometimes you can resoke it a few times if dries out too Depending on type of wood.
Think it needs to be steamed before its applied :001_unsure: , what wood is it your trying to cut?
I steam the veneer I buy so I can get tight bends with it, but with the bandsaw thin bits it just snap. They are a bit thinker though. I have some real nice blanks of purple heart and other exotic ones i'd like to use. The veneer i buy of those types of wood have quite a wide grain, so on a ring there's not much detail.
I was wondering about using a real good plane to get 1mm shavings, and they would come off curled up already wouldn't they? Do you think that would work on dried wood Ian?
Drier wood will be harder to be honest but if you bansaw it say 5mm thick then soak it overnight that might work then peel it down thinner, plus i find it doesn't curl when wet.
What timber r you doing it in
