80ft Pine Fell
Ian Flatters
  • Replies 22
how do you get the back bit out? i am thinking you just have to bore a triangular shape hole:001_smile:
you bore in at a angle and cut a triangle section out so your two boreing cuts meet, it should just pull out easy if not hit with a hammer will soon knock it loose. on bigger trees you can afford to just cut a whole box out the whole width of the back and stick a line of jacks under it. :thumbup:
