it wont make a difference when felling, provided the end result complies of a hinge minimum of 1 inch or 10% of the true diameter of the tree. but it is a waste of timber. i was taught an inch at the bottom is worth a foot at the top. thats probably why its seen as bad practice (in a forestry sense). the angled back cut is a reconised copice technique.:icon14:
  • Replies 24
thats what i thought 3 dogs,but the people preaching its bad probably dont have to deal with coppice and leylandii regrowth
if the stem is that thin then you can cut and hold, or cut and snap, if it is too heavy then you should be able to bore cut and leave a conventional horizontal hinge, I dont see any need for a downwards back-cut, it is bad practice
so you have 2 leaning stems together with little gap and they need to be felled opposite ways, there about 20ft tall and 3 inches in diameter.........what do you do then?
i cant see it being bad practice on the odd occasion, this jobs all about doing what works safely and aslong as you start high so you still have a hinge and step then why not????:bongsmi:
Angled cuts are hard to wedge, or lever. Also the grain is harder to read- too easy to cut through your hinge if it does not run vertical
yes but in a situation its acceptable
I was taught on forward leaning trees, you do your usual sink, then bore in, then fell by cutting at a 45 degree to stop it spliting, but on a normal fell you wouldnt do your felling cut at an angle, it is bad practice, as has been said you couldnt wedge or use your felling bar properly.
