New to fixing my own saws
Bob Rolfe
just started to do my own work on my own saws i guess this i this is the right place to ask ......
A. Where do i get where do a get manuals from like for Haynes cars but you know for saws
B. Where do i get parts from off tinternet
c. Why are so many bloody screws... i always loose them
d Where can i find cheap screws
When I strip something down, I try to lay the parts out in sequence, and same with the screws nuts & bolts. Get a bun tin, you know the ones with about a dozen small "bowls" for the mix, then as you remove screws etc, place them in correct order in each "bowl" so you can remember the sequence of removal.
a regular service should see a very reliable saw.
clean/replace air/fuel filters, replace plug, clean tank vent, a damn good clean, a carb kit every now and then and a new pull cord is all thats needed.
check the pistin ring/s for wear once in a while as my husky had worn right through (opposite the ring gap) and was just about to fall apart, if that happens its normally new pot/piston, possible bearings etc as the ring will snag in the ports and destroy everything.
fixing a saw is not rocket science, the most technical part will be the carburettor but once you understand how they work its easy :biggrin:
