Between £20 and £40. There should be a number on the side of the bearing so you can either quote that to your local dealer or just unbolt it and get the replacement off the shelf.
ok thats great , presumably if it is the bearings that have dropped it will only be the bearings that need replacing or is there anything else i should be looking for ? i started a thread on this yesterday and to cut a long story short the bottom roller looks like its to low , have gota have a play tommorow :001_huh:
