So was wondering how much a well dress corretly tied knot, will take out of a climbing line.
e.g climbing line 2700kg, knot takes out 1000kg and then splice in end takes out 200kg( = full strength of climbing line 1500kg) or will it just break at
1700kg due to the knot?
be helpful if some one could give a exmaple like this but with the correct answer and rating on true strength on rope and knot.
1. Bowline?
2. Double Bowline?
3. Alpine Butterfly?
4. Fishermans?
be handy to know, cheers matt
  • Replies 22
any knot reduces tensile strength by about...........erm............wait for it.............cant quite remember now.
Think it is by between 40 and 60 percent.
Scary huh???
The reduction of two knots dont compound to weaken the rope,but the knot with the bigest reduction in the system is the one that would be relevent regarding max break or SWL.
Otherwise you could put three or four knots into the system and it would (with a 30% loss) fail under its own weight!
Knot Break Strength vs. Rope Break Strength
Of course !! :001_smile:
Obviously due to the bend in the rope. But i think it is more specifically due to only a small portion of the diamater of the rope taking the load. Its a bit like tension and compression in wood. The inside of the bend takes little load, with the outside being under tension taking most of the load. As the very outside is loaded severely it can cause a shearing action.
I seem to remember that if a rope is shock loaded,then you get friction/heat,and also a distortion of the rope structure by the tightening.
