Good old bus with a cab big enough to have a barn dance in, and a steering lock you need 25 acres to turn round in.
Gear linkage a bit fancy and subject to wear.
Not really a great road tractor, but excellent pto and heavy draught workhorse.
Cab parts such as door difficult to find replacememnts for. Good strong perkins engine, none turbo as standard, should do 10,000 hrs before rebuild if its been maintained well.
Wot he said plus, simple to maintain. They are nice and basic, anyone with a couple of spanners can look after one in the middle of a field. No complicated electronics to worry about.
It probably won’t be cheap.
When I sold mine the exporters were all over it like a bad rash.
Andy
good powerful tractor, not much electical on them to go wrong, and most can be fixed in the field if it does, turning circle of an ocean going super tanker, but pretty bomb proof, just check for play in the front axle and steering (especially check the center pivot grease nipple has been greased) as any wear to these can cause you big head aches, I run a 2720 the bigger version for baling with and its a big steady old tractor but they are very cheap hp really
