Hi all, probably had this conversation many times in here but just need some confirmation from you bods that the information below is correct?
Kilonewton (kN) is a measure of force= force of 1 kN of gravity would be exerted on something that weighs approximately 224.8 pounds (lbs).
1kN = 224.8 lbs
I would also like to know how one calculates Velocity+Static wieght= KN force load
and finaly is there some symbols for velocity, Static wieght and force?
Thanks :thumbup:
  • Replies 61
1 KN = 224.8 Pound force
Can't really help with the second part of your question.
Have you downloaded Uconeer? Its a handy little conversion tool that someone posted on here some time ago.
Hama, if it's of any use I've calculated some close figures to your imperial measurements.
A 90kg mass falling 25m (approximate to your suggestion) with almost no travel after initial impact (the rope catching the falling mass) will exert a force of 315000 N on the system.
So that's a force of 315 kN.
best keep the slack out of our ropes eah! thanks for that!
:thumbup:
Remember - that calculation assumes almost no stretch in the rope.
To give a more useful result we could assume a stretch of 1m, thus giving a final force of just over 22 kN.
What you may be wanting are a combination of speed distance calculations and force calculations. I did A level physics and maths back in the day and vaguely remember working out stuff like above.
v=u+at where v = final velocity u = initial velocity + acelleration x time
v= 9.81x3
final velocity is 29.43 metres per second
s=0.5xat2
therefore the distance fallen is 0.5*9.81*9 = 44m approx 150feet
I may come back and calculate the force later. But my brain hurts.
Edited by detritus21
spelling
