Fungus id is not my strong point, but learning all the time:001_smile:
First is on a London Plane (a big one!), could it be a species of Ganoderma?
2nd photo is on a Scots Pine (old Phaeolus perhaps?)
Thanks...Al
First picture is not characteristic of a Gano....the sporulation is white, and you would expect it to be brown. Funnily enough, more like the second image. That said, I am not certain how to annotate the bracket in pic 1. It would be consistent with aspects of Rigidoporous ulmarius.
AIE - Tree Fungi - Rigidoporus ulmarius
The second image is significantly degraded...could be a Phaeolus spp. I would feel more confident were you able to say whether this was found in asssociation with Armillaria spp. Not much help Im afraid !
Ok, thanks for your input both.
Maybe Monkey D might have something to say about Rigidporus on a Plane tree?
The tree in question is in Portman Square in London.
Rgds..Al.
The fungus on the plane could be Perenniporia fraxinea too though, would be worth taking out a piec of it to see the tube layers.
After googling for images of both, there is an image of the rigi that looks virtually identical, even with the green algae on top.
The perenniporia does not look qite the same. If I am back there I will take a sample and photo.
Thanks for your help,
Al.
I dont doubt it is Rigidiporus, but with the potential to also be perreniporia it is a simple matter of cutting into the flesh to clarify and be certain. perreni will be a constant even colour throughout. hence the name fraxinea due to the consistant one colour like the wood of ash as apposed to fraxinea being its host preference! latin can be misleading at times!
  • 1 year later...
Didn't know that :blushing: thanks for the tid-bit!
