I've had to resort to Stripping !
Dean Lofthouse
  • Replies 33
Its about £3500/ ton at the moment for clean copper. Weight it yourself before you go though! Never trust a scrap man lol. And thats from one of my best mates who has a big scrapyard :)
Took some nickel in last week. £16000 a ton :) :) Happy days!!! Although only had a small bit and nowhere near a ton.
how are you stripping it dean?
Its hard work stevie
I got a peice of Ali bar, drilled a hole through it the size of the wire so it slides ove the cable nicely.
Then I drilled a hole through sideways and threaded it to fit a grub screw in, I then sharpened the grub screw and just screw it in far enough to cut through the sheathing
All you do then is slide it on the cable and pull it along, it leave a slit in the outer sheath then you can simply peel it away, can do 50m in about 5 minutes
Well worth spending time stripping it though for the extra money
