treeimagineers hitch climber
Branch walker
  • Replies 27
Please be carefull Rich, the top of the knot is so so close to the hitch.
That rope has been retired after a groundy cut it in half... all spliced up at the moment until another unexpected meeting with mr silky.
I think that the picture is a bit misleading, angle an all. the hitch is about an inch below the bowline.
But yes it is something that every one should be aware of when using the HC. :thumbup:
Does the hc always have to have two crabs in the two holes? I've used a petzl William pear carabiner and there's enough room to have both the friction hitch, the HC and also the spliced eye. Just as a way of eliminating metalwork?
I've climbed on a knut for a while so not needed to use mine. But I'm thinking of trying the vt. I've tried it a bit but had no proper usage so can't compare it.
you could well get away with just using a small micro pulley then. the hitch climber is designed so that the components that build the climbing system are pulling inline with one another to eliminate unnecessary/uneven karabinar loading. to use it any other way would defeat the purpose of the tool!
I tried using a micro pully and never got on with it, using the hitch climber has been a revelation.
at first i used a single oval below and a HMS above, now it's two ovals and works a treat
Jamie
