I think you should have CS41 for that. And use of saw from a MEWP as well. CLimbing with saw ticket covers using one from a mewp. (top handles that is, if they are using larger saws that may be ok)
Good question for AA tec.
Haha, you didn’t mention that!
As soon as you start rigging i.e. not just cut and chuck then you’ll fall into Best Practice and Risk Assessments. I wouldn’t attempt rigging with a MEWP without the associated NPTC ticket, because if there was an accident the first thing the HSE would want to see is proof that the operators knew what they were doing.
Maybe this is a grey area that needs to be addressed…
as above
as far as i am aware your use of a chainsaw up a tree is sufficient to use a saw from the MEWP. but, if you dont have that there is a specific unit for chainsaw from a MEWP.
clearly rigging is seperate, you'd need a rigging ticket and grounds man with the same or groundsman ticket
but to use any saw from a mewp requires training to meet best practice
as dose using the mewp its self!!!!!
ps
im pretty sure using a chainsaw up a tree covers you to use any saw up a tree
Edited by Rod
missed a bit
as above
ps
which is crazy when you think of it ,i never used a 395 on my climbing course !
but it dosn't specify!:thumbup:
just that you can use a chainsaw from a rope and harness:thumbup:
try the 880 with the four foot bar on
Edited by Rod
added a bit
