28 minutes ago, Robert kirkland said:
Hi everyone, I have a stihl ms391 and the spark plug threads are damaged on the engine side i think is there a remedy for this ? Probably come loose and blown out
Helicoil or similar . Spud used a better one but I cant remeber the name .
53 minutes ago, Alan Smith said:
Timesert is usually considered to be a bit better than Helicoil.
Thats the one. 🙂
TBH, both helicoil or Timesert will do an effective job if done correctly. One bit of advice is to use a decent quality tap and usually a taper one otherwise there is a distinct chance that the tap will go in at an angle causing sealing issues.
I use Volkel taps as they are decent and not OMG expensive, avoid all these cheap Chinese alternatives as the job is as strong as the quality of the receiving thread.
From what I've read they are the best option. Expensive but good. I've repaired a fair few cylinders using a helicoil and they haven't yet failed. I will only do this for a good customer and I wont guarantee the work as opposed to replacing the cylinder which I know sounds like a cop out but when someone has already stripped the threads before I'm not having them come back in a year with the same issue and blaming me. New cylinder, its 100% their fault.
Personally for thread repair in general I see a Helicoil as the proper engineering solution for stripped threads, and some of the top engine builders use them as standard in alloy cases in new engines.
But I agree that with a short reach sparkplug with only 4 or 5 threads a Timesert is probably a better solution for most folk that don't have the correct tooling or experience.
Without trying to blow my own trumpet over my working life I repaired thousands of damaged threads and I can say that I detested finding Timeserts in casing threads of an engine that I was repairing for every possible reason.
