Agreed, very interesting. Something must have moved to create that tension. That smaller trunk, (or is it another bigger, aerial, root?), that's being girdled - has that leaned over at some point? It doesn't look to be vertical and seems to be welding to the main trunk.
More photos required.
2 alternative explanations. Could have been a surface runner. Or could have been a shallow root but ground has subsequently been reduced in level. I have seen something like it before in poplar which had had a foot of woodchip dumped at the base, had had suckering roots into the chip and then the chip had rotted away.
It's very typical pit remediation woodland. Ground is loose, piss wet and on a slope. Soil slipping out from under it is quite plausible.
