Strange occurrence on my oldest 2016 MS 261 it didn't just unwind to my knowledge, it was running great but suddenly the sparkplug popped out and saw dead.
I tried red loctite, that lasted until the saw got properly hot again.
Is there anything else I can do to fix the sparkplug in, tap out a wider hole or some permanent metal glue perhaps before consigning it to the parts bin ?
I could do with an old near valueless saw to keep at my wood storage for occasional use.
It's only ever been run on Aspen
On the plus side, I now have a damn good excuse to buy a new saw, been over two years since I did that
      Cheers
          Stuart
Helicoil (thread insert
 probably a 10mm or 14mm kit
WWW.EBAY.CO.UK
M10 x 1.0mm Thread Repair Kit. For Stihl MS171 Using NGK CMR6H. A recoil repair kit comprising of Part No. 7122. 10 coil inserts. Tang remover.
Edited by tree-fancier123
29 minutes ago, MattyF said:
I never found the spark plug on this one… would not like to guess where it went 🫣
Something tells me that a fresh sparkplug might not change it's fortunes overnight...
  • Haha 3
That was its original bar from one of the first 500i , it’s had two nose sprockets on ..one a few weeks before 3 t of ash pinched and rolled on it popping the saw apart anyway..
I know years back I had 200ts which had the spark plugs helicoiled back in … they never lasted though , I’d just buy a new head or saw.
I always used Vcoil from Volkel helicoil taps, good value but decent quality. Those Chinese cheap ones are....cheap but not cheerful in my experience.
You would need what is referred to as a "tapered tap" as the tapered part screws in to the remains of the tap and leads the main larger tap to ream and tap the hole to the larger size to take the new helicoil.
You get one chance to get it right and the taper gives you a decent chance of getting the new thread pretty square with the old one.
It is a bit of a skilled job, may be one for the local old fella engineer type that just gets on with it rather than tweeting about how great he is👍
