Had a customer drop in yesterday with a 562XP. Basically as soon as you tighten the bar nuts the chain gets really tight, slacken the nuts of a tiny bit to get the tension right and the chain moves around the bar by hand nicely, tighten the nuts down and it hardly turns. I only had a quick look at it, bar and chain are matching, it had the same issue with his old bar and chain, nothing seems to be out of place in regards to the chain getting pinched, the drum isn't contacting the sprocket cover although the clutch springs are really slack but they didn't cause tick over issues which I thought strange, and there didn't seem to be too much movement in the clutch bearing and the guide plate looked OK. I will have a proper look over it next week starting by swapping out the sprocket cover to rule out any issue with that. Im thinking that somehow the bar is somehow twisting causing the issue.
He also said that he seems to be replacing the rim sprocket more often than usual, the rim floats freely on the drum.
Has anyone came across this issue before?
Whe  the nuts are slackened a tiny bit, is the bar lifting up away from the saw, if somethings bent so its not sitting correctly until fully tightened, that will do it.
With saw on its side, slacken nuts, adjust tension, press down on the tip of bar, whilst somone holds the saw and see if tension changes.
