Inner tube installed.. plus some other uses for the inner tubes.
I will be selling sections of inner tube for £1 + VAT, + postage for those interested 20251106_190857.thumb.jpg.be76b78d7ff17445720cbb499d6625bf.jpg
Stops carabiner spinning
Holds a carabiner secure on a tool strop and keeps a bit more length compared to girth hitching
Edited by Ledburyjosh
I can imagine several cyclists returning to their pedals to find scraps of cut innertube hanging out, near to a freshly cut stump 😆
Kong, and I'm sure others, do a twisted carabiner which would allow the bar to sit nicely parrallel to the harness. Might prevent the chain catching on trousers.. I dont know if it would.
UKRIGGING.NET
Special “helical-shaped” connector with a twisted carbon steel body and circular bar, a must-have when an “offset” load is required. It permits 90° rotation...
Cannot beat an old inner tube - so many uses. Also see 'Wild Sling' for another use. And windfalls.
21 hours ago, kram said:
Husq do this thing, I assume something like that but with a big enough ring to have a tool stop and clip onto harness?
Seen this, D ring and a couple of steel cable ties.
UKRIGGING.NET
Good to know, if I find it may be better oriented 90 degree more I will give one a go
Another idea is a biner could be tied in that orientation, no need to buy a twisted. This is 3mm starter cord, 4mm might be better. Barrel knot, get it tight and add a barrel stopper.
IMG_20251107_114827.thumb.jpg.16073c639cc14ed868fa6a1e55266d1f.jpgIMG_20251107_112756.thumb.jpg.0aaf59ff233bd0398d3f8625ee133424.jpg
Carabiner easily unclipped when not needed. Going to leave this tied and add one to my other ground saws.
Edited by kram
I had one of these on my 461 and it worked well. I'm not sure I would 100% trust it in the event of accidentally dropping a saw that size on your strop though.
UKRIGGING.NET
Hmmmm, I’m Pretty certain I’ve managed to make at least a couple of these over the years.
