1 hour ago, covex said:
So far it's working and saving effort to make smaller branches and feed every piece manually but hey, the larger branches it can consume are heavy too...
It looks fairly slow operating in the video, only chipping a 2/3'' diameter branch -can you not increase the feed-in speed any more?
Also, I thought that the internal grill could be removed, to give a larger chip size?
Not too impressed -I guess it's only powered by a 13hp engine tho.
Yes, its 13hp, the branch that was in there is cca 10cm diameter (4"). but you are right the end of the branch was thinner.... It can have a higher feed speed, but for this diameter it's having problem to discharge the chips and clogs because the RPMs slows down too much (nostress stops feeding but RPM drop anyway) - its visible on the video. I may try to fine-tune the nostress RPM low limits (its possible to set on this machine).
I am yet to try to remove the internal grill...
Edited by covex
16 hours ago, covex said:
Thanks for your correction -I didn't realise it was actually a 10cm thick branch .
So, that's actually quite good productivity, for a machine powered only by a 13Hp engine..
When I quizzed the Carlisle agents, they were insistent that their bigger 25Hp engine unit made no discernable difference to chipping performance, only to tracking speed up an incline.
Hence they would only now sell the 13Hp engined units.
Perhaps I'd better get up to Carlisle, to test out the demonstration unit.
Edited by green heart
Afterthought!
It's completely crap either way?
Otherwise would be the only chipper in the world where doubling hp makes no difference.
  • Haha 5
Well yes, maybe its crap when compared to a bigger tracked 6'' Forst/Jensen/Timber wolf/Greenmech etc
However -it's smaller, lighter, suitable for those awkward little 'back garden' type jobs -and significantly, it costs a fraction of the others listed..
I don't suppose it'll last 25 years like my current Cramer and Timber wolf, but hey, horses for courses !
Got to be brutally honest. I know I was a GreenMech rep for 27 years,  but, if you tried to trade that for something else, I'd allow £25 in the deal for nothing to do with it! Everything has it's place in the market but I would not give it yard space. Buy cheap and buy twice. Support a European or English manufacturer rather some distant folk who dont supply the industry or support it with warranty or support.
You don't need to convince me on the mini chipper, I bought an approximately 10 year old JoBeau M500 about 8 years ago for £3k. Blades, belts, bearings, little bit of weld, some yellow paint, still chips like a champ.
I can see the attraction of cheap Chinese, I have a cheap stump grinder but the main reason that doesn't break very often is that I hardly use it.
PeteB and Dan, I'd 100% agree with you, re: supporting UK/EU manufacturing, every time -I always detest/avoid buying Chinese goods or tools..
I'd actually spoken with the Greenmech designer/director about two potential improvements to the CS100, prior to likely buying one (-and he was already independently considering one of the mods, then ).
But that was 2 years ago now, and sadly, it's evidently gone nowhere, in the light of recent sad takeover news there..
So, against all my principals, it's likely to be the Chinese/MDL chipper ( itself a copy of a Japanese machine !), the best replacement for my small chipper. It has the valuable addition (to me) of a feed roller and tracks, over the M500 JoBeau unit.
I'd be the first to support the local production, but there is nothing like that and made in china is everywhere, even my bosch pro pruners are made in china, which was quite disappointing to me.
Never mind I came today to report I had a first track derail on machine - but was my fault as I was turning on the big gravel and the stones got into the track derailing the idle wheel. I was lucky enough to load/unload the chipper to/from the trailer with derailed idle wheel and fixing this in the garage. At least I was forced to find the proper tension for track - it's 15-20mm bottom track slack from the roller. Finding this I think my tracks come with too much tension on them.
Edited by covex
Was chipping a large thuja (this is a pain for any chipper), so perfect "test" to remove the grill (screen with 40mm holes) as with it the dispatch was clogging a lot. It helped to avoid the clogging most of the time, but the size of the chips did not increased significantly (there were larger chips, but not overall). Also this is not recommended so far as it may cause that large chunk of the wood gets into dispatch fan causing some damage. Chipper was not able to "consume" more than 3" of this kind of wood while previously chipping many apple tree branches was going up to 4" without issues.
The funny thing that happen was, that after a few hours, the RPM started to show completely insane values and the no-stress obviously stopped working without correct RPMs, becoming a "stress" control (manually stopping and starting the feed). When I got back I found one grounding wire screw got loose, causing this strange behaviour.
Edited by covex
