My horizontal anvil sheared off and spat itself out the chute, is there anything you would recommend replacing while I have it stripped? I was looking to see online where the anvil goes etc but I’m a bit lost. If anyone has done this or has pictures it would be fantastic. This is the current shape I have it sitting in
If its horizontal anvil that's a lump of metal to go through chipper, would of thought its damage discharge fan.
But I can't see how it been thrown out as it's got to get past or through blades.
Vertical anvil in its entirety went through my ForstST8, made a funny noise for a bit then clang! and out it came.
I think there’s space under the rotor disc, between it and the chamber for it to pass underneath.
I would replace both anvils, rotor bearings, and check rotor fans for damage.
I think they replaced the old ally fans made of cheese for better ones at some point, may be worth checking with your dealer.
Edited by Mick Dempsey
Thanks for the help guys. Was very easy to fit, no damage done thankfully though I will change the blades in the next month or so.
Goes in here, just to the right hand side of the opening.
Last time I tried speaking to timberwolf technical they were absolutely not interested and said I needed to speak to my local dealer, worlds apart from when I spoke to the technical department 10 years ago they practically bent over back wards to help with my queries.
I’d check the bearings, blades, and bolts while you have it apart. If the anvil sheared off, chances are other parts took some stress too. Make sure the bed knife area and mounting threads aren’t damaged. It’s also a good time to replace any worn belts or hoses since access is easier now. A few close-up photos of the anvil mount might help others point out what’s missing or bent.
Also, check the flywheel and shaft for cracks or play. If the anvil let go, it might’ve thrown things out of balance. Spin it by hand once everything’s apart and see if it wobbles or rubs anywhere. I’d also clean out all the built-up debris before reassembly—sometimes small chunks get jammed in spots you don’t expect and cause more damage later.
Edited by Field Builds
