Anybody got a link to service manual for valves etc. Also haven't had one of these float bowl carbs apart for years. 3 screws in pic - 2 on top one next to float nut. Guessing one of the top ones must be idle. What are the other 2? No choke currently won't restart after warm. Cheers - any help appreciated
There's no choke because the primer bulb squirts petrol in the intake to richen it. When you press thebulb your finger covers the hole that allows fuel to drain back when running.
The screw at the bottom of the float chamber is just a drain.
I think the silver screw opens the butterfly to increase tickover revs. The other is probably the slow running mixture.
The screw at the bottom of the float chamber is just a drain.AGREED THANKS
I think the silver screw opens the butterfly to increase tickover revs. AGREED THANKS The other is probably the slow running mixture. I TUNED THIS TODAY LIKE A 2 STROKE CHAIN SAW SCREW - FINDING THE MID POINT BETWEEN DYING SCREWED OUT OR IN THEN RICHENED IT UP A HALF TURNISH TI ACCOUNT FOR WOEK UNDER LOAD. HAD NO INSTRUCTION ON THAT JUST GUESS WORK. THANKS FOR YOUR REPLY
12 minutes ago, mikerecike said:
Which valve is which pls? Both same distance away from exhaust & carb???
Take the plug out. The inlet is the one that opens as the piston goes down and the exhaust opens as the piston comes up as long as the engine is rotated in the right direction.
If you find TDC by placing something like a sccrewdriver into the plug hole and rotate the engine until the screwdriver is at its furthest point protruding outwards, it it is on the correct stroke then both valves should be fully closed (so you can 'waggle' both rocker arms so they arent under any pressure) then you can adjust both valve clearances...on briggs OHV engines its between 0.004" and 0.008" this is a Honda clone, so may be different. If on the stroke where you have TDC only one vavle rocker can be 'waggled' then you will need to rotate the engine fully so the next stroke will close both valves.
