Has anyone had any issues with the mark 3?
Mine sh!t it self last week blowing the plug out its housing stripping the threads
Its either not been tightened fully or had dirt in the thread - making it feel tight but still being loose. I had the same on my CBR600 motorbike.
Should be quite easy to helicoil. Best to pull the cylinder off first so it can be reassembled clean, but on the CBR6 I helicoiled all four in situ as getting a 4T bike engine apart and back together is a fairly huge job.
If you do it with the saw assembled, set the engine with exhaust port open, use plenty of grease on the tap to catch any swarf then flush it out with 2t mix fuel.
I've done that with a car engine (Subaru 1800 turbo) . Near bdc on the induction stroke pump grease in. Bring piston up until grease at bottom of plug hole. Tap thread, screw in helicoil, break tang then bring piston to tdc to eject grease with tang and swarf. Spin engine with plug out to expel excess grease.
Not worth doing with a chainsaw engine when you can pull the pot so easily. Well worth using the special helicoil stepped tap to ensure it goes in straight.
Edited by openspaceman
posted from fone with predicted text
Care needed but you can helicoil them without stripping the engine but care with where the piston is, grease and stuffing the cylinder is all part of it as is using the compressor airline with the exhaust port only slightly open is all important.
Its an existing square drilled hole, the tap will want to follow it square and unless your cack handed it wont be a problem.
Now if you've never used a helicoil before I have an important tip - release the pressure on the insertion tool every half turn and go slow. The wire is like a spring. If you instead, wind it in continuously or fast, the wire will wind up smaller than the thread, when that happens it will jump, and then you have a problem! You do not want a helicoil wire to jump out of the thread. If it does on a chainsaw engine, your best to try winding it all the way through and hope the unsupported tang doesnt snap off early, start again with a fresh one.
Its also wise to drill and tap a hole in some scrap to practise with first.
Edited by kram
9 minutes ago, kram said:
Its an existing square drilled hole, the tap will want to follow it square and thats a minor concern.
If you use the stepped tap it will start following any vestige of original thread, the cutting bit of the step will ream out a hole which is the inner diameter of the helicoil's thread, the tap above the step will then form the new thread.
If you use just a single helicoil tap you will need to drill first, this is where mistakes happen.
The helicoil is just like the one way clutch you can make with a pencil and a spring of a slightly smaller diameter on it. You can wind it in because you are drivng in by the tang and, as you say the torque causes the spring to wind up and shrink its diameter slightly. Try and unscrew it and it attempts to unwind and jams against the thread, this is why it doesn't extract itself when you take a plug out. it's also why it is most important that the helicoil is short enough to sit totally withing the length of thread. Having a piece of helicoil sticking out of either end of the threaded hole is a disaster. I have never had one jump a pitch when inserting.
