Tractor transmission oil overheating. ( Valtra 6400)
On 24/08/2025 at 21:34, MattyF said:
I’ve had brakes and every thing heat up on 6400 when the brake servo has started to fail.
Yeah.  Valtra mechanic they can corrode after a while and cause brakes to stick on slightly. I changed one this evening.
Hopefully makes the difference.. I got about 8miles from home and had to ring for a fire extinguisher as I thought it was going to burst in to flames !! Local Valtra mechanic said straight off it’s the brake servo.
