4 minutes ago, skc101fc said:
Oooh didn't mean to do that... was just about to say one of the easiest places to clog up, and also easiest places to clear is the little hole where oil enters the saw bar, and then onto the moving parts of the chain. A small hole of about 2-3mm diameter on the upper part ofhe bar, about 5mm down from the top guide rail surface, where the bar is clamped to the engine.
Shouldn't have to be describing this , but I'm beginning to feel that maintenance and regular care don't occur very often with this case.
If you're  local to me please don't being it in for repair. I've had a few machines in that have had used engine oil for chain oil. They either get picked up without me looking at them or get binned. The next down the line is veg oil machines!
Some little trick ive used for a while since you dont need to start the saw up if you want to check for oil flow and you have an air compressor handy just spin the drum up with a blow gun pointed at the sprocket splines/rim. No chance of a clutch explosion using this method.
Still didnt help me solve an oiling issue on a t540i though!
