It looks like you've replaced a lot of parts. Is the piston and cylinder kit, and ignition coil oem?
Have you tried using the old carb as aftermarket ones are hit and miss at best. You also need to make sure the basics are good, fuel line is good with no leaks plus the fuel filter is good. Spark plug is not a fake ngk as ive seen a few of them which wont spark properly under load. Fuel filter is sitting at the bottom of the tank, sounds silly but Ive fixed a few machines where the filter was jammed up at the top of the tank.
Got it running now. Runs great on idle and when throttle is applied. I cleaned a breather pipe and this some how sorted it out. As for oem parts, the piston, cylinder and coil are genuine. The crank and carburettor are after market. An original crank is £200. Hopefully it runs now. May put the original carburettor on but get it pressure tested as previously mentioned.
On 21/08/2025 at 18:46, Mark_Skyland said:
It's good to hear that you've got it running. It is worth using the original carb if you can get it sorted.
Hi. Sorry for my late reply. Tried using that after it's rebuild but still no joy. I'm starting to think that this particular model of saw has a carb with no priming bulb which personally speaking is a problem. The models before and after the TS400 both have priming bulbs.
Get it gone on EBay to try and recover some of your losses and buy a decent machine, Husqvarna K760/770 or oil guard version even better, by far the best power cutter on the market.
