The saga continues.... Got the new switch and fitted it BUT although the key operates the ignition LIGHTS
turning it to the right to get the starter motor to turn does not work   The supposed diagram supplied by the supplier of the switch has different colours to the colours on the actual switch   The earth and the power are black and orange  that is pretty clear  The other three colours on the machine itsefl are respectively
Red / Grey (sort of grey)
Purple which the diagram says goes to the ignition cut out switch and a component I cannot fathom on the diagram
Orange/green/blue
The diagram has Blue / red  and
Red
The actual wiring is on the photo and I  have downloaded the diagram as a pdf.
not sure if it will work!
1 - K C A (91-02).pdf1 - K C A 1 - K C A (91-02).pdf(91-02).pdfam
So my question(s)
Assuming the orange and black are right  What are the other colours?
What colour is equivalent to the missing colours
or was the replacement switch the wrong one?
It was sent on the recommendation of a Countax expert
Chris
Personally, you paid over the odds for something that should be a bolt on solution.
Don't mess, just return it and get the right one.
As whatever you do to change it will bite you on the arse next time 🙂.
Plus the old one is knackered, take a wi brush to the back and see what's written and you might have a better chance of finding a fleabay special 🙂
Edited by GarethM
Genuine Countax/Westwood switch is only £35.00, but obviously unless you are near to a supplier you will have postage on that. They are a very common failure item.
