I had an ex TW dealer tell me that it was a 4 hour job to do those, plus parts. Northern folk pay half the price of southern folk?
We look after loads of TimberWolf TW125's and done countless flywheel bearings.
As Pete says, 4 hours is about right. Hopper off, unbolt hydraulic motors, lift roller box off, remove flywheel belts, remove front pulley, remove flywheel housing backplate and rear bearing housing. Unbolt front bearing housing and lift out flywheel. It's the perfect time to turn the anvils on the flywheel back plate and roller box.
You could rush the job and do it in probably 2-3 hours.
So what sort of price?
Bearings are cheap on those. £100 would cover the parts bill. Bearings and consumables. 4 hours labour at £70 + VAT would be £240 + VAT. Should see it done for sub £500 including a blade sharpen and new blade screws.
It isn't uncommon for the bearings to be turning on the housing, so it could need the bearing housing, the belts could well be cracked, the anvils already turned so needing replacement. Fan blades on the discharge side need checking thoroughly for any cracking. This could easily double the bill.
Without inspecting the machine its just a blind guess.
  • Thanks 3
Nice one GA for putting it out there and being honest👍. All I’ll add is throw in a Rotor nose shaft and rear shaft( the op hopes it’s just the bearings?) and possible pain in the arse to remove these and you could add another £5/600?
Good shout on the rotor shaft.
In the past 12 months, we've probably done a good 75 flywheel jobs at a guess on various makes, if not more. We have 5 chippers in our workshop currently without flywheels fitted.
Almost every customer books in as "just bearings". Very rarely it is just bearings alone.
Edited by GA Groundcare
