20 hours ago, peds said:
Yes please spud.
Low and slow on the heat and flow....and don't get me going on why electric is 4X the cost of gas meaning a COP of 4 is needed to break even. I inherited the pump and is offset by the PV panels FIT otherwise heat pumps are not worth it unless you are a true eco warrior and want to bankroll the saving of the planet.
Heat pumps are actually pretty economical, around 3500KW on all electric we use other than space and water heating, the same....3500KW on heat and water heating where 12,000kw of gas would be typical for our house.....cost wise...errrr....the same, fantastic! Why don't the people trying to get us to go for these pumps just lower the electric cost for them:hmmmm2:
I have left out two years of trying to get the most out of the thing!!
It's the getting multiple stage heat setup thing I fail to understand as you can't get 60c+ water cheaply.
Oh it'll do hot water, technically yes but probably cheaper to have economy 7 hot water and separate central heating off the heat pump at 30c or whatever the maximum cop allows. 3.5kw at a cop of 4 is 14kw or maybe at 5 17.5kw
Heat pumps will work for us... no gas supply... so heating electrically for the same price as gas has its merits. Add in a couple of solar panels... but while there is excess tax on electricity that isn't on gas (at the point of use) heat pumps won't make sense to most. Still need an immersion heater or under sink electric heater for hot water though.
6 hours ago, organic guy said:
Yes please! Really.
Well I did....see earlier post....... bearing in mind that ours is some 12 years old so probably not as "user friendly" as the modern ones.
We are running a flow temp of 34 degrees during the day....yup, you read that right....as I said, Low and Slow, that is how this old banger likes it. It is these cold winter months that are the worst. May look in to one of these low heat pump rate tariffs but many charge more during peak so they may just balance out.
We do maintain 17-20 degrees at this flow temp for 95% of the time so not too bad on that front.
Edited by spudulike
Just looking to set ours up to tick over while we away. It appears that when the engineer showed me how to, he left it slow and low mode which shows up as low steady electric use, probably a better way to run it although we did have it tripping out because flows were too low.
We'll see what happens this week
I would turn the heat pump off for any periods of 2 days and upwards as long as it isn't in the winters worst weather. The amount of electricity a HP will use over two days is more than an initial ramp up after being turned of however we do have a wood burner.
Heat pumps don't like flow temps of under 25 degrees, our night time temp is 26 degrees and it has remained reliable.
Our HP is pretty old but a rough COP is 3-3.5 based on average UK gas figures and our power consumption - we cant see how much the heating uses so have estimated our yearly use based on average UK use plus our previous house usage.
