Would anyone know the difference between the V1 and V3? I am tempted to get one at V1 prices but there doesnt appear any difference in the spec.
I assume if there was a recall, they wouldnt be selling the V1.
Not exactly sure but the original (I assume v1) wasn’t CE certified.
Matbe that is the difference?  I have had one of the early ones since they came out.
Still fine and climb on it today.
Gotta be honest it’s not a bit of kit I’m not comfortable with, used it a few times and it’s just sat in the bag in favour of the pinto biner option.
Matty, I think it is safer than the pinto option IMO.
I know they did the break testing years ago with the branch and pinto / alpine butterfly tie off and the branch broke before the kit.
I find the quickie is easier to retrieve.  A little bit more space and the loop of the butterfly doesn’t contact with the running end of the rope.  Which I find happens with the pinto bina setup.  11mm rope.
I also find that when you come to retrieve the pinto/bina option it can sometimes get stuck or Jammed other branches or unions.  Usually when you don’t have a straight pull as you have come down a different route than the retrieval leg.
Just my observations over the years of using both options.
  • 1 month later...
A new CE version... Price has gone up!
Interesting they have dropped stainless for the body, it is now made of steel with a chrome finish. Needed to pass en326?
I'd like one but not at 60 quid!
HONEYBROS.COM
The Notch CE Quickie is a compact, CE-certified steel connector designed for arborists. Tree-friendly, lightweight, and perfect for redirects, anchors.
