IMG_20241005_152847_HDR.thumb.jpg.80d4750c4d9cffbc80a7d0998756e3dc.jpgIMG_20241005_152831_HDR.thumb.jpg.0e9809dadf6fb77c4fc6869bd68675ba.jpgEvening all.
Looking to replaced & fit a new cylinder/pistol kit to my 346xp, grey clutch cover version . Seems to be 44mm bore judging by the id marks.
Any recommendations for a decent supplier ?
Edited by jackdaw
More pic
Rebuilt my 346xp (2013 with grey clutch cover) a couple of years ago using a Meteor cylinder and piston. Ordered from Garden Hire Spares online as L&S Engineers only had genuine items at a fair bit more money. It’s done a fair bit of work on the Meteor kit and runs really well. Good luck 👍
Hi Spud,
The saw was increasingly hard to restart once hot, eventually to the point it refused too. Not great compression & just didn't sound right on pull over at that point, bit clunky.
Stripped it down and the piston is scored badly on the exhaust side & the ring almost fused in the slot on 1 side.
The cylinder doesn't look as bad to be fair.
Edited by jackdaw
That may be aluminium pick up stuck on the nikasil rather than scores through it. Worth cleaning up chemically and a light hone before condemning it. My 346 arrived back like that and is now my goto saw.
I missed the response, as previously mentioned, if the plating is not scored through, clean the bore up chemically, abrade the oxide off, lightly hone/rub the bore with wet and dry and then fit a new piston.
Just be aware that the OEM bore is an odd 44.3mm so the replacement piston needs to be the same and not 44mm or 45mm.
