I’ve seen a 340 that looks to be hardly used and runs well etc at decent money (150), and want a more capable saw than my 135. It’s still only for dealing with fallen limbs etc at the cave I look after, but after a morning clearing up a fairly sizeable ash today I felt like a longer bar than 14” would have been good for the main stem (which I left for now) and generally a bit more grunt/speed would have been nice.
so a couple of questions, a: is the 340 worth a look and b: is the 346 top end mod fairly straightforward and worthwhile?
When my mate came to do the climbing / felling at the weekend he managed fine with an MS261 so maybe I should hold out for one of those rather than risk spending whatever one would cost used trying to modify a saw that isn’t ideal in the first place?
ADW will tell you if its possible or not @adw but if my memory serves me at all the 340 is a plastic crank case halves machine , The 346 is metal  and much more a pro saw . I would not do it . Save up for a 550 mk2 . This will run a 15" bar with ease and an 18" occasionally . If you need an 18" all the time then a 560 or 562 which will run a 20" on occasion .
Thanks @Stubby I felt like I’d answered my own question while I was asking it tbh but I’m a nightmare for buying cheap and then spending just as much fixing things or just ending up buying what I should have in the first place.
this is very much a case of want vs really need, hence trying  to go cheap. I’ll save up!
The 340 has the top crankcase moulded in to the lower part of the cylinder making it a typical "Clam" type engine so modifying it with a 346XP cylinder isn't possible.
The 350 however, has a separate metal moulding making up the top crankcase and this gives it a flat base where the 346XP cylinder can be fitted and is a known mod although I have never done this.
Both the 340 & 350 have a plastic cradle that the metal parts are bolted to and the lower crankcase is formed by the plastic cradle.
This IPL will show you what I mean: -
340_340Е_345Е_350.pdf
Edited by spudulike
Thanks  @adw @spudulike - the clam aspect would explain why the US posts I read talk about needing the cylinder base too. Just need to find a suitably good nick pro saw for the right money instead. Patience has never been a virtue of mine unfortunately
