19 hours ago, eggsarascal said:
All  in one diesel heater outside the building, buy/make a box to keep the weather off, core drill two holes into the building, one for air/heat in the other for.air intake, job done. Recycle the warm air equals less fuel, step down unit from 220-240v to 12v s about £30, no need for battery or charger, only downside is if there is a power cut the heater won't go through it's cool down process and could melt the motherboard, chances are slim of it happening and a cheap fix if it did.
I have one inside my shed, it will keep the frost off but takes all day to raise the temp a few degrees. Works well enough, a bit noisy but not massive output if the shed is of any size.
