I have a landy tipper and the electric pump is playing up, the catridge valve has stopped working, there is power to it coz i have checked. i think the magnetic valve has burnt out. can anyone help please. where to get one or a new pump system. thanks.
try taking the pipe of the ram to se if its pumping , .it could be the solinoid if fitted mine does no & then
it goes up fine mate,( i should have put that in my post) its just lowering, the valve is operated by an electro magnet. thanks for you help.
