I diced up a pile of branches with a pole saw once. Rested the head on top of a chicken coop, upside down so pulling chain on top, my mother on the throttle, me feeding the logs. Actually worked really well.
3 hours ago, Stere said:
When cutting stems on ground standing straight up with a long bar won't it be hard to avoid dirt with the chain as you cutting logs with bar tip is held at a 45 degree angle
I normally crouch down so bar is cutting more lvl with ground then flip logs over for that last bit.
But recall seeing yanks on youtube who use say 24" - 30" bars or whatever  ringing up pretty small diameter stems on the grounnd with the tip of long bar and not flipping logs but they  probably had a brash mat underneath.
That is where I saw it. It’s 12 inch limbs mainly that I asking for. Obviously the bigger stuff gets done kneeling with as short a bar as I can get away with.
i suffer from old age and back problems so even on my 560 im running a 26 inch bar and skip tooth chain so i have less bending . as long as your chain is kept  nice and sharp and you dont try to rush its been fine .
