On 22/03/2023 at 05:48, doobin said:
I take it that's with a hitch plate?
Another company that might be worth a look is A13 Engineering. They have a range of Hardox grabs which are clearly based upon the Intermecatto and the prices are keen. I would have purchased one for my new backhoe but there is a big gap in the range for that size machine. Here's the spec sheet they sent me.
Just had time to have a good look at there grab and compare they must have some steel in them as only 4 tines and come in heavier then intermecato one of the same size digger also opens up bigger.
  • 3 weeks later...
So the plan is to use grab off loader set up and see how we get on with it.
Made headstock, biggest problem is fixing bolts same as arm width so a bit of head scratching to get over it. Have also made a plate to fit under side so you undo 4 main bolts and just spin it the just out bolts back.
If it works well will probably buy A13 engineering grab from what I have see of them they are a 4 tine grab.
