Mines getting pretty worn now so thinking of replacing it before it snaps. Is it an easy enough DIY job to change it? It’s a Posch S280. No idea how much the belt will be yet either so if anyone knows that too that would be great. Thanks.
1 minute ago, Justme said:
On my duun 420 i converted from a glue jointed belt to one with a joiner.
Made installing it soo much easier.
They join them all the time on the screen conveyors on gold rush (small bolts)
This is more like a row of small hinges where you pull out the pin.
That's what the one that's on it is like and the one I've ordered should be the same. Hoping I can tap the pin out, connect the new end to the old end and as I pull the old one out it will pull the new one through if that makes sense.
