Weld and grind works. You'll have to put a weekend aside, well, that's how long it took me to get rollers out, couple of beads on both edges, grind and put it all back together.  Worth it though. Make a note of the edge angles, because you tend to lose them when the bead is on. I ground one first, before beading the rest and used that as the guide
Edited by Con
