That's a (partial) setup for the RADS (Rapid Ascent/Descent System)
There should be a micro pulley in there as well.
I started on this system, it's useable, not great. Basically it's the setup for industrial rope access and good for that application. Excellent for going straight down, not so good for going up and bad for moving around laterally in the canopy. Hard to advance the climb line. It works for rope access because it's main feature is easy and foolproof rapid descent. Rope access guys rappel off the top of a structure to reach their work position. Not too much ascending involved.
Whereas we climb the rope/tree to our work position, and must have a retrievable anchor.
I switched to trad double rope after a few years of frustration. But my RADS system still comes in handy from time to time. If I can get the single rope through a good high crotch, I can use it to haul up my double rope and pulley, then basal anchor the single rope with the Grigri/descender. This allows someone else to lower me if need be, and the descender devices are pretty rugged and foolproof.
I wouldn't buy the setup again though.
Why not just rappel straight down from the top of the tree instead? It'd be loads quicker.
Anyway, Petzl ID is a great bit of kit for all sorts of things, but there's no way on Earth that I'd choose it for moving around in a tree unless it was the only thing available.
Spend the money on something else... like a prusik...
