Clutch scoring side casing
nemcc
Get some pics up as it will make the issue more obvious.
If the "C" moulding on the side cover is getting worn away, it may be the clutch has been spinning off on  de-acceleration.
If the drum has been rubbing on the side cover, I have seen similar from one of the clutch shoes having a damaged retainer allowing it to come off the centre boss although your badly worn needle bearing is possible but difficult to tell without feeling the wear.
Post a pic of the clutch and cover, it may help.
