A mate of mine has had the kohler ch740  engine go bang big time on his predator 460 hybrid.
The kohler engine is a 455 day lead time from our normal supplier (unipower dunmow), if anyone has any suggestions for suppliers please let me know!
Or has one lying around 😅
Alternatively,  has anyone fitted a different engine to one of these machines? Thanks.
B&S/Vanguard and Honda V-twin engines should fit. They often have the same mounting holes,  just make sure you get the right driveshaft. Manufacturers often deliver with different size/style driveshafts on the same engine model.
Loncin is another alternative that might be a bit cheaper to buy.
  • 6 months later...
  • 2 months later...
What hp is that replacement engine and how much did it cost?
might need a replacement for a kohler 27 hp but can’t tell until it’s been properly looked at
thanks
thanks
This is a screenshot of the Facebook advert we got it from, 29.5hp according to google👍
It was new but  secondhand so I don't know the retail price of one.
Thanks
Found it online for just under that new. Was it a straightforward swap including safety cut out etc etc
Clutch a straightforward fit etc ?
Thanks
Physically mounting it wasn't too difficult, I think they just had to put a little crossbar under one side. Wiring wasn't too difficult in the end apparently, although a wiring diagram would have helped as there are safety cut outs etc but I think a bit of patient tracing got it sorted 👍
