Probably the plastic plug in one....degrease both with brake cleaner and I use a US sealer called "seal all" but you may get away with cyanoacrylate or super glue to the uninitiated.
Just make sure you don't get it on the breather parts, just the outer casing.
On 24/03/2022 at 19:28, peatff said:
Could have been worse, he could have said push the manifold onto the flange as well😏
im glad he didnt say first put some lube on your nipple then slip the rubber on .
This is the breather, it is slightly possible it has been loose for a long time and worn the hole larger...I trust it was an OEM part.
WWW.LSENGINEERS.CO.UK
Fuel Tank Vent fits Husqvarna 135, K770, K970 Brushcutters Genuine Husqvarna Part OEM No. 501 15 29 01 Suitable for the Following Applications: 135, K770, K970, K760 CUT-N-BREAK...
