Hi people have finally got some trees lined up to cut for firewood they have been like hens teeth so took the carb off the husqvarna 555 today and this is what I found there is I link rod missing between the throttle and bottom butterfly it’s not lying in the saw could people that know the saw run there eye over the pictures and see if anything else is missing or if it has been modified thanks E45F8F5A-91BB-4FA9-B77A-55586EFC9717.thumb.jpeg.fa2c991cb423e3767e37f13d8c079926.jpegkE45F8F5A-91BB-4FA9-B77A-55586EFC9717.thumb.jpeg.fa2c991cb423e3767e37f13d8c079926.jpegE45F8F5A-91BB-4FA9-B77A-55586EFC9717.thumb.jpeg.fa2c991cb423e3767e37f13d8c079926.jpeg4D7DF01E-82A4-4032-ADDF-78B688897B18.thumb.jpeg.160e7fa76e897c2f5095390b32eca738.jpeg
You need @adw
It all looks like it’s there, I have never seen a link rod actually fall off, if it did it would still be hanging about? This is a very early carb as can be seen by the angle of the fuel inlet pipe on the carb, I have plenty of scrap carbs if you want a link rod, just send me a message. If the tank breather is still connected to the filter elbow with a hose remove it and leave the breather open to air, you can also turn the carb fuel inlet elbow round so as to move the fuel hose away from the back of the cylinder area, you will need to shorten the hose, these two things help hot re starting.
The joys of buying second hand equipment...lol do you think this would cause the problems with stalling after coming off full throttle ?
