Stihl 201t idling problem
AWarb00
My 201t is playing up at the moment, starts fine , but won't idle for very long
Iv tried turning the L screw back , and nothing seems to change, tried turning it forward , nothing either .
Almost sounds like it's running out of fuel but the tank is full
And when warm it only likes to start on half choke
Any ideas?
I had similar problems with my 201. Not Mtronic version. Took it to a recommended dealer to get the problem sorted. They fitted a new carb, ignition module and fly wheel. Parts were subsided by stihl because they knew there was a problem with the original parts. Had the work done aroundb 2018. Saw was probably 2016 ish. Still dicks about a bit now. Doesn’t like to idle until it’s hot but even then it’s not great
