As of yesterday I have no more water extraction from the kiln. I’ve had 15 litres of water out in total with negligible amounts for a thimble the past few days.
today is day 11 and have now turned the dehumidifier off and have started the heat schedule to 140*f and was at 131 when I left this morning.
humidity had plummeted to 18% and as the dehumidifier cannot extract that last amount I am running the extraction vent to exhaust any minor moisture.
once the 48hr cycle is completed the kiln will be left naturally to cool. 🤞
Edited by Big Beech
2 hours ago, Mr. Ed said:
I’m intending to use this gadget to measure the RH, temperature and MC - not expensive and seemingly well made, and you don’t need to open the box.
The Protimeter BLE is a compact battery-powered device that measures and logs Relative Humidity, Temperature and...
I use the inkbird humidity and heat controller, they can be found on popular sites.
Edited by Big Beech
Airflow is relatively important, to much and dried to quick and to little takes to long.
vanity fans as far as I could see had no volume figures available and those that did it was like a hurricane! I need to look in to my fan issues again as one has failed again, but that’s cheap fans from china for you.
This morning I was able to get some boards out of the kiln, mc figures where around 6-10% on average over a board that is 8ft x4. Few zones where slightly higher up to 12 where stickers had rested.
three boards have been readmitted for a bit longer. One was a thicker 3” board so as to be expected that wasn’t so dry and was reading 14% and the other two where around the 12 mark.
overal very happy 😃
