makita dcs 6400
petefran
18 hours ago, Stere said:
Think  the 7900 might fit also if you want?
http://download.dolmar.com/manuals/25357.pdf
I think this chart is showing piston and cylinder come in 47mm, 50mm and 52mm variants for the 6400, 7300 and 7900, so the 7900 wouldn't fit on its own.
It used to be possible to upgrade a 6000 to a 6800 by changing just piston and cylinder so you might still consider swapping to 7900 spec if the cylinder is shot. Most likely you'll get away with new piston and cleaning up cylinder though.
I can't get cylinders for 6000 and more but I did get a new piston from @shavey ajschainsaws . May be worth looking him up.
