  • 2 months later...
On 18/11/2021 at 11:42, Robbinson said:
Hodge, in your opinion you prefer the sg40 to the jo beau 37? Pros/cons for each?
cheers
Did you come to a conclusion in the end over the Grinder?
  • 1 month later...
The SG 40 is excellent, there are a couple of things I preferred on the JO Beau but overall the Bandit is excellent. The Razor Wheel is far better than green teeth, they cutter hold an edge longer and don't break as often, they are easier to sharpen too. The Bandit could do with the cutter being able to fold up out of the way like the Jo Beau did and also would be better if it had a deeper grind but I can manage. Overall the build quality on the Bandit is better in my opinion, apart from the access to one of the drive bearing being bloody annoying. This is one of the things that lets it down but it only takes a few mins to remove the cover to grease it, the other is the stupid petrol tank filler.......overall the Bandit is a better machine in my opinion.
I ended up with the bandit zt1844 and I also added the remote grease line on all my hard to reach grease nipples, was super easy to do just screw cut to length and screw then in basically. I got mine from my local bearing supplier. Think I paid £12
