Crewcab Tow Tug? Ford? Toyota? Isuzu?
Just now, scraggs said:
Biggest problem we had off road was you had to think about what you was doing well before you done it.
If you were in hi range and got bogged down and stuck it appeared to wind the diffs up and you couldn't get it into low range.
We just always ran it in low range off road in the end, but several times we had to be towed out.
Off road I always went straight for low as high range first is pretty highly geared on them - occasionally it would be a bit of a bitch to get back into high 2wd (which I’d forgotten about but was sometimes a pain in honesty).
I genuinely loved mine - it towed my Landy out a couple of times too….
1 hour ago, PeteB said:
There are still Navara models available, what are they like?
They are the most economical it seems . From  2019 onward the rear coil springs were up rated .  2.3 bi turbo 190hp approx .
